StarTech.com 6ft mDP to HDMI cable - 4K
£17.07
11 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Achieve astonishing picture quality with support for 4K resolution at 30 Hz
  • Reduce the clutter caused by adapters with a cable that connects directly from your computer to your display
  • Avoid the hassle of power adapters, with a plug-and-play cable adapter that does not require external power
  • Stock Status: In Stock
Product codes
Eliminate clutter by connecting your Mac or PC directly to an HDMI display. This 6-foot Mini DisplayPort to HDMI adapter cable offers a single-cable connection from your mDP equipped MacBook or Ultrabook laptop to an HDMI display or projector. The passive adapter supports video resolutions up to Ultra HD 4K and is Thunderbolt compatible when connected directly to a supporting DisplayPort over Thunderbolt I/O port.
This adapter cable ensures you can maintain an astonishing picture quality, four times the resolution of 1080p, when converting Mini DisplayPort to HDMI.
The adapter is also backward compatible with lower resolution displays and video sources. With support for high-definition resolutions of 1080p and 720p, you can future-proof your existing setup for 4K video.
For the simplest and most discreet installation, this mDP to HDMI adapter connects directly from your Mini DisplayPort video source to the HDMI port on your display. It doesn't need a power source, unlike some converter dongles that require active power and separate video cabling.
At 6ft in length, this adapter cable delivers a compact connection that eliminates excess to ensure a tidy, professional installation. For shorter installations, StarTech.com also offers a 3 ft mDP to HDMI cable (MDP2HDMM1MW) enabling you to choose the right cable length for your custom installation needs.
The MDP2HDMM2MW is a stylish white adapter that looks great next to your Mac computer.
Product Description StarTech.com Mini DisplayPort to HDMI Converter Cable - 6 ft (2m) - mDP to HDMI Adapter with Built-in Cable - (M / M) Ultra HD 4K (MDP2HDMM2MW) - video cable - DisplayPort / HDMI - 2 m
Cable Video cable - DisplayPort / HDMI
Length 2 m
Colour White
Connector Mini DisplayPort - male
Connector (Second End) HDMI - male
Compliant Standards DisplayPort 1.2
Features 4K support
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 6ft mDP t...
£17.07
