This 6ft Toslink to Miniplug digital audio cable offers an easy way to connect your Toslink devices to Miniplug devices, allowing you to get the most out of your digital audio gear, even at extreme volumes.
Thinner than the regular audio cables, the cable provides one Toslink male connector and one mini-optical male connector and features flexible PVC jacket construction that lets you bend the cable into any position you need without damaging the cable or losing any sound quality.
Product Description | StarTech.com 6 ft. (1.8 m) Toslink to Mini Toslink Cable - Toslink to Mini SPDIF - Audio Cable - Black - Digital Optical Cable (THINTOSMIN6) - digital audio cable (optical) - SPDIF - 1.8 m | Cable | Digital audio cable (optical) - SPDIF | Technology | Fibre optic | Length | 1.8 m | Connector | TOSLINK - male | Connector (Second End) | Mini TOSLINK - male | Manufacturer Warranty | Limited lifetime warranty | Designed For | P/N: ICUSBAUDIO2D, PEXSOUND7CH |
General | |
Cable Type | Digital audio cable (optical) |
Interface Supported | SPDIF |
Jacket Material | PVC |
Length | 1.8 m |
Connectivity | |
Manufacturer Warranty | |
Service & Support | Limited warranty - lifetime |
Compatibility Information | |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
