StarTech.com 6ft USB-C mDP HDMI to HDMI
£112.02
Delivery:
Standard: 1-3 working days
Key features
  • Avoid the hassle of using multiple adapters in a single boardroom or classroom
  • Be prepared for all of your presentations and different user requirements
  • Astonishing video quality with support for video resolutions up to 4K at 30Hz
  • Stock Status: In Stock
Product codes
Connect your USB Type-C, HDMI or Mini DisplayPort laptop to an HDMI display or projector. This unique adapter cable lets you connect almost any laptop or desktop computer to an HDMI display or projector. It supports the USB-C, HDMI and Mini DisplayPort output from your computer, and video resolutions up to Ultra HD 4K.
The adapter is compatible with your DP alt mode computer. DP alt mode means your computer can pass a DisplayPort video signal through the USB-C port.
This adapter cable is ideal for your boardroom's HDMI display or projector. You can reduce clutter and eliminate the need for multiple adapters on your boardroom table by providing a single adapter cable that can support a variety of signals.
The adapter cable supports multiple input signal types, so you'll be able to accommodate a variety of user needs. Employees and guests can plug in their USB Type-C, HDMI or mDP laptops and deliver their presentations using your boardroom's HDMI display, without having to carry their own adapters.
This adapter cable ensures you can maintain an astonishing picture quality with four times the resolution of 1080p. The adapter is also backward compatible with lower resolution displays and video sources. With support for high-definition resolutions of 1080p and 720p, you can future-proof your existing setup for 4K video.
The adapter can be powered through the provided Micro-USB cable by connecting the cable from the adapter to a USB port on your laptop or the HDMI display. You can connect your laptop to either input on the adapter cable, and share presentations.
Product Description StarTech.com 6ft USB-C, HDMI or Mini DisplayPort to HDMI Adapter Cable - video converter - black
Device Type Video converter
Interfaces 1 x HDMI input - 19 pin HDMI Type A , 1 x DisplayPort input - Mini DisplayPort , 1 x USB - 24 pin USB-C , 1 x HDMI output - 19 pin HDMI Type A , 1 x USB (power only) - 5 pin Micro-USB Type B
Dimensions (WxDxH) 6 cm x 2 m x 1.5 cm
Enclosure Colour Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 6ft USB-C...
£112.02
