StarTech.com 6ft USB-C to A Cable - USB 2.0
£12.28
43 in stock
Delivery:
Standard: 1-3 working days
Key features
  • USB-IF Certified
  • Convenient, reversible USB-C connector makes every connection easy
  • Guaranteed reliability with our lifetime warranty
  • Length: 2m
Product codes
Connect your USB Type-C devices to your computer, over longer distances. This USB-C to USB-A cable makes it easy to charge and sync USB Type-C devices, such as the Nokia N1 tablet and Nexus 6P and 5X phones, using the USB-A port on your computer. You can also use the cable to charge your USB-C mobile devices from a standard USB-A wall or car charger.
The 2-meter cable gives you the extra length you need to overcome distance restrictions and stay connected. You can charge and sync your USB-C mobile device, in almost any environment. Even while you're taking notes in a boardroom, catching up on emails in your hotel room, or reading in a coffee shop, your mobile device will reach your computer or wall charger more comfortably.
The cable has undergone rigorous compliance testing and is certified by USB-IF (USB Implementers Forum) to meet all USB 2.0 specifications. This includes all environmental, electrical and mechanical standards, ensuring a reliable, high-quality cable for all of your USB-C devices.
Product Description StarTech.com USB C to USB Cable - 6 ft / 2m - USB A to C - USB 2.0 Cable - USB Adapter Cable - USB Type C - USB-C Cable (USB2AC2M) - USB-C cable - 24 pin USB-C to USB - 2 m
Type USB-C cable
Technology Double shielded
Length 2 m
Connector 24 pin USB-C - male
Connector (Second End) 4 pin USB Type A - male
Compliant Standards USB / USB 2.0
Colour Black
Designed For P/N: HB30C1A1CPD, HB30C3A1CFBW, HB30C3AGEPD, HB30C3APD, HB30C3APDW, HB30C4AB, HB30C4ABW, HB30C4AFPD, HB30C4AFS, ST4200MINIC
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£12.28
