StarTech.com 6ft USB-C to DisplayPort Cable
£24.94
Select:
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Reduce clutter with a USB-C to DisplayPort adapter and display cable, in-one
  • Get astonishing picture quality with support for UHD video resolutions up to 4K 60Hz
  • Make the perfect connection with a monitor cable that works with any USB-C enabled laptop
Product codes
This USB-C to DisplayPort adapter cable offers a convenient solution for directly connecting your DisplayPort over USB Type-C device to your DisplayPort monitor or projector, at up to 6 ft. away.
The adapter works with USB-C devices that support DP alt mode, such as the MacBook, ChromeBook Pixel and Dell XPS models 15 and 13. It's also compatible with Thunderbolt 3 ports.
At 6 ft. (1.8 m) in length, this adapter cable delivers a compact connection that eliminates excess adapters and cabling, ensuring a tidy, professional installation. For shorter installations, StarTech.com also offers a 6 ft. (1m) USB-C to DP cable (CDP2DPMM1MB), enabling you to choose the right cable length for your custom installation needs.
The adapter cable is easy to connect, through the versatility and convenience of the USB Type-C port on your desktop, laptop or tablet. USB-C is a reversible connector, so it doesn't matter which way you plug it in, the adapter will always connect, saving you the frustration of trying to insert it correctly when you're trying to dock your computer to your workstation or office hot desk.
At four times the resolution of high-definition 1080p, you'll be amazed at the picture quality of a 4K monitor or television. This adapter cable lets you harness the video capabilities that are built into your USB Type-C connection, to deliver the astonishing quality of Ultra HD to your 4K display.
Plus, the adapter is backward compatible with 1080p displays, which makes it a great accessory for home, office or other work environments.
Your USB-C equipped device must support video (DP alt mode) to work with this adapter.
StarTech.com 6 ft / 1.8 m USB C to DisplayPort Cable - 4K 60Hz - Black - external video adapter - STM32F072CBU6 - black
External video adapter
Bus Type
USB-C
Graphics Engine
STM32F072CBU6
Max Resolution
3840 x 2160
DisplayPort (male connector)
Length
1.8 m
Enclosure Colour
2 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 6ft USB-C...
£24.94
