StarTech.com 6in 20 Pin Motherboard to 24 Pin ATX Power Adapt...
StarTech.com 6in 20 Pin Motherboard to 24 Pin ATX Power Adapter - M/F
£4.62
29 in stock
Delivery:
Standard: 1-3 working days
  • Type: Power
  • Stock Status: In Stock
Product codes
This 20 to 24-pin Power Supply Adapter features a 20-pin Male ATX connector as well as a 24-pin Female ATX connector, providing a cost-effective way to connect a 20-pin compatible motherboard to a power supply with a 24-pin connector, allowing the use of a newer 24-Pin Power Supply with an older 20-Pin Motherboard.
Product Description StarTech.com 6in 20 Pin Motherboard to 24 Pin ATX Power Adapter - M/F - power connector adaptor - 15.2 cm
Type Power connector adaptor
Length 15.2 cm
Connector Power 20 pin ATX - female
Connector (Second End) Power 24 pin ATX - male
Designed For P/N: ATX2POW500HS, ATX2POW450HS, ATX2POW400HS, ATX2PW550PRO, ATX2PW500PRO, ATX2PW450PRO, ATX2PW400PRO, MICATXPOW255, MICATXPOW145, ATXPOWER250
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 6in 20 Pi...
£4.62
