StarTech.com 6in 4 Pin Molex to Left Angle SATA Power Cable A...
StarTech.com 6in 4 Pin Molex to Left Angle SATA Power Cable Adapter
£3.87
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Compatible with both 2.5” and 3.5” Serial ATA Hard Drives and allows the use of newer SATA hard drives with older power supplies, which eliminates power supply upgrade costs
  • Left-angled, 90-degree SATA power connector allows this cable to be used where normal straight connector cables cannot, accommodating tighter space limitations while minimizing strain on the cable and also the drive's SATA connector
  • Backed by a StarTech.com lifetime warranty
Product codes
Power a SATA hard drive from a conventional LP4 power supply connection. The SATAPOWADPL Molex to 90-degree SATA power adapter features one 4-Pin Molex (LP4) male connector and a left angle, 90-degree SATA power connector (female), which enables you to power a Serial ATA hard drive from a conventional LP4 connection and eliminates the need to upgrade the computer power supply for compatibility with the SATA hard drive.
The 90-degree (left angle) SATA power connector makes it easier to connect a SATA drive that's installed in hard to reach areas or tight spaces, avoiding the strain on both the connector and cable.
Product Description StarTech.com 6in 4 Pin LP4 to Left Angle SATA Power Cable Adapter - power adapter - 15 cm
Type Power adapter
Features Left-angled connector
Length 15 cm
Connector 15 pin Serial ATA power - male
Connector (Second End) 4 PIN internal power - male
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 6in 4 Pin...
£3.87
