StarTech.com 6in 4 Pin Molex to Right Angle SATA Power Cable...
StarTech.com 6in 4 Pin Molex to Right Angle SATA Power Cable Adapter
£4.93
23 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Compatible with both 2.5” and 3.5” Serial ATA Hard Drives
  • Allows the use of newer hard drives with older power supplies
  • Right-angled connector allows this SATA cable to be used where normal straight connector cables cannot
  • Backed by a StarTech.com lifetime warranty and free technical support
  • Stock Status: In Stock
Product codes
This 6-inch 4-pin (LP4) Molex to right angle SATA power adapter features one 4-pin Molex (LP4) male connector and one (female) right angle SATA power connector, allowing you to power a Serial ATA hard drive from a conventional LP4 connection, eliminating the need to upgrade the computer power supply for compatibility with the SATA hard drive.
Product Description StarTech.com 6in 4 Pin LP4 to Right Angle SATA Power Cable Adapter - power adapter - 15 cm
Type Power adapter
Features Right-angled connector
Length 15 cm
Connector 15 pin Serial ATA power - male
Connector (Second End) 4 PIN internal power - male
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 6in 4 Pin...
£4.93
