StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter
£3.57
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Compatible with both 2.5” and 3.5” Serial ATA Hard Drives allows the use of newer hard drives with older power supplies
  • Backed by a StarTech.com lifetime warranty and free technical support
  • Length: 0.2m
  • Type: ATA
  • Stock Status: In Stock
Product codes
This 6in 4 Pin (LP4) Molex to SATA power adapter cable features one 4 Pin Molex (LP4) male connector and one female SATA power connector, allowing you to power a Serial ATA hard drive from a conventional LP4 connection, eliminating the need to upgrade the computer power supply for compatibility with the SATA hard drive.
Product Description StarTech.com 6in 4 Pin LP4 to SATA Power Cable Adapter - LP4 to SATA - 6in LP4 to SATA Cable - 4 pin to SATA power - power cable - 0.2 m
Type Power cable
Length 0.2 m
Connector 15 pin Serial ATA power - male
Connector (Second End) 4 PIN internal power - male
Designed For P/N: BNDTBUSB3142, BRACKET125PT, BRACKET125PTP, BRACKET225PT, BRACKET425F, HSB13SATSASB, HSB1SATSASBA, HSB1SATSASVA, HSB43SATSASB, PEXUS313AC2V, PEXUSB311A1E, PEXUSB311AC2, PEXUSB311AC3, PEXUSB311EI, PEXUSB312A2, PEXUSB312C2, PEXUSB312EIC, PEXUSB314A2V, PEXUSB3S3GE, PEXUSB3S42, PEXUSB3S7, SATBP125VP
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 6in 4 Pin...
£3.57
