This reliable EPS adapter combines a P4 power supply connection with an LP4 power supply connection, into a single 8-pin EPS motherboard connector, allowing you to use a non-EPS power supply with a motherboard that requires an EPS power connection.
StarTech.com 6in 4 Pin to 8 Pin EPS Power Adapter with LP4 - F/M - power adapter - 15.2 cm
Power adapter
Length
15.2 cm
Connectors
Power 4 pin ATX12V connector - female
Connectors (Second End)
4 pin internal power (5V) - male , Power 8 pin EPS12V - male
Power adapter
Length
15.2 cm
Connectors
Customer reviews
