StarTech.com 6in 4 Pin to 8 Pin EPS Power Adapter with LP4 - F/M
£4.22
More than 50 in stock
Delivery:
Standard: 1-3 working days
Product codes
This reliable EPS adapter combines a P4 power supply connection with an LP4 power supply connection, into a single 8-pin EPS motherboard connector, allowing you to use a non-EPS power supply with a motherboard that requires an EPS power connection.
Product Description StarTech.com 6in 4 Pin to 8 Pin EPS Power Adapter with LP4 - F/M - power adapter - 15.2 cm
Type Power adapter
Length 15.2 cm
Connectors Power 4 pin ATX12V connector - female
Connectors (Second End) 4 pin internal power (5V) - male , Power 8 pin EPS12V - male
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 6in 4 Pin...
£4.22
