StarTech.com 6in DVI-D Dual Link Digital Port Saver Extension...
StarTech.com 6in DVI-D Dual Link Digital Port Saver Extension Cable M/F
£9.62
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Backed by StarTech.com Lifetime Warranty
  • Easy to use and install
  • Prevents repairs to your computer or display by extending the port to eliminate the stress that would be placed on the port by a DVI-D cable
  • Length: 15.2cm
  • Stock Status: In Stock
Product codes
Extend a DVI-D port by 6in, to prevent unnecessary strain on the port. The DVIDEXTAA6IN 6-inch DVI-D Port Saver Cable/coupler avoids expensive repairs to a computer or display. It does this by extending the port by 6in, thereby eliminating the weight and stress that would typically be placed on the port by a DVI cable. This is especially useful in an environment where cables are unplugged and re-inserted frequently.
The 6in DVI-D cable supports resolutions of up to 2560x1600 and transmission rates of up to 9.9 Gbits/sec, and is fully compliant with DVI DDWG standards.
Product Description StarTech.com 6in DVI-D Dual Link Digital Port Saver Extension Cable M/F - DVI-D Male to Female Extension Cable - 6 inch - 2560x1600 (DVIDEXTAA6IN) - DVI extension cable - 15.2 cm
Type DVI extension cable - dual link
Length 15.2 cm
Connector DVI-D - male
Connector (Second End) DVI-D - female
Compliant Standards RoHS
Colour Black
Designed For P/N: CDP2DVIMM2MB, DP2DVI2MM3, DP2DVI2MM6, DP2DVIMM10, DP2DVIMM6, DP2DVIMM6BS, DP2DVIMM6X10, DVIDDMM10, DVIDDMM6, DVIDSMM10, DVIMM6, HDDVIMM3, HDMIDVIMM10, HDMIDVIMM6
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 6in DVI-D...
£9.62
