StarTech.com 6in DVI-I Dual Link Digital Analog Port Saver Ex...
StarTech.com 6in DVI-I Dual Link Digital Analog Port Saver Extension Cable M/F
£10.32
Delivery:
Standard: 1-3 working days
  • Type: DVI
  • Length: 15.2cm
  • Stock Status: In Stock
Product codes
Extend a DVI-I port by 6in, to prevent unnecessary strain on the port. The DVIEXTAA6IN 6-inch DVI-I Port Saver Cable/coupler avoids expensive repairs to a computer or display. It does this by extending the port by 6in, thereby eliminating the weight and stress that would typically be placed on the port by a DVI cable. This is especially useful in an environment where cables are unplugged and re-inserted frequently.
The 6in DVI-I cable supports resolutions of up to 2560x1600 and transmission rates of up to 9.9 Gbits/sec, and is fully compliant with DVI DDWG standards.
Designed and constructed for maximum durability.
Product Description StarTech.com 6in DVI-I Dual Link Digital Analog Port Saver Extension Cable M/F - DVI-I Male to Female Extension Cable - 6 inch - 2560x1600 (DVIEXTAA6IN) - DVI extension cable - 15.2 cm
Type DVI extension cable
Length 15.2 cm
Connector DVI-I - male
Connector (Second End) DVI-I - female
Compliant Standards RoHS
Colour Black
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 6in DVI-I...
£10.32
