StarTech.com 6in Latching Round SATA to Right Angle SATA Seri...
StarTech.com 6in Latching Round SATA to Right Angle SATA Serial ATA Cable
£4.89
Delivery:
Product codes
Make a right-angled connection to your SATA drive, for installation in tight spaces. The LSATARND6R1 6-inch Round SATA cable is a high quality SATA 6Gbps cable that features a rounded design to help improve airflow inside a computer or server case by providing less resistance as air passes around the cable, in turn helping to ensure cooling for improved system performance.
The cable features one straight latching SATA connector, as well as a right-angled latching SATA connector that makes it easier to connect your SATA drive even if space near the drive is limited. The latching connectors also ensure secure connections to SATA hard drives and motherboards that support this feature.
Product Description StarTech.com 6in Latching Round SATA to Right Angle SATA Serial ATA Cable - 6" Round Latching Right Angle SATA Cable - Improved Air Flow (LSATARND6R1) - SATA cable - 15.24 cm
Type SATA cable
Interface Speed Serial ATA 150/300/600
Features Latched, right-angled connector, round
Length 15.24 cm
Connector 7 pin Serial ATA - receptacle
Connector (Second End) 7 pin Serial ATA - receptacle
Colour Black
Designed For P/N: 35S24M2NGFF, CFAST2SAT25, USB2SATAIDE, USB3SSATAIDE
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 6in Latch...
£4.89
