StarTech.com 6in Latching SATA Cable
£4.00
Delivery:
Standard: 1-3 working days
  • Length: 15cm
  • Type: SATA
  • Stock Status: In Stock
Product codes
Secure latching SATA cable designed for new system boards and SATA hard drives. The LSATA6 SATA Cable features two latching 7-pin data receptacles and supports full SATA 3.0 bandwidth of up to 6Gbps when used with SATA 3.0 compliant drives.
The latching connectors lock when connected to a supporting (latchable) SATA port, ensuring a snug, and secured data connection every time to prevent accidental disconnects.
Featuring a low profile, yet durable construction, the flexible design improves airflow and reduces clutter in your computer case, helping to keep the case clean and cool.
Product Description StarTech.com Latching SATA Cable - SATA cable - 15 cm
Type SATA cable
Interface Speed Serial ATA 150/300/600
Features Latched
Length 15 cm
Connector 7 pin Serial ATA - receptacle
Connector (Second End) 7 pin Serial ATA - receptacle
Colour Red
Designed For P/N: 25SATSAS35, 25SATSAS35HD, 35S24M2NGFF, BRACKET125PT, BRACKET125PTP, BRACKET225PT, BRACKET425F, CFAST2SAT25, HSB225S3R, SATSASBP425, ST521PMINT, USB2SATAIDE, USB3SSATAIDE
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 6in Latch...
£4.00
