StarTech.com 6in Latching SATA Power Y Splitter Cable Adapter...
StarTech.com 6in Latching SATA Power Y Splitter Cable Adapter - M/F
£5.32
37 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Eliminates the cost of upgrading a computer
  • Guaranteed reliability
  • Prevent accidental disconnections
  • Length: 15.24cm
  • Stock Status: In Stock
Product codes
Add an extra SATA power outlet to your PC Power Supply. The PYO2LSATA 6" SATA Power Splitter Cable features a SATA 15-pin plug that connects to a single computer power supply SATA connector and breaks out into two latching SATA 15-pin receptacles, which enables you to connect two Serial ATA drives to a single SATA power connection on the computer power supply.
The latching SATA power connectors ensure a secured connection to the drives, preventing accidental disconnects, while the Y-adapter power split eliminates the cost of having to upgrade the power supply to accommodate an additional SATA drive.
The PYO2LSATA is constructed of only top quality materials and designed for optimum performance and reliability.
Product Description StarTech.com 6in Latching SATA Power Y Splitter Cable Adapter - M/F - power splitter - 15.24 cm
Type Power splitter
Features Latched
Length 15.24 cm
Connector 15 pin Serial ATA power - male
Connector (Second End) 2 x 15 pin Serial ATA power - female
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 6in Latch...
£5.32
