StarTech.com 6in LP4 to 6 Pin PCI Express Video Card Power Ca...
StarTech.com 6in LP4 to 6 Pin PCI Express Video Card Power Cable Adapter
£3.84
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
  • Type: Power
  • Stock Status: In Stock
Product codes
Convert a Standard LP4 Power Supply Connector to a 6-pin PCI Express Video Card Power Connector. This 6in LP4 to 6 Pin PCI Express Video Card Power Adapter converts a standard LP4 power connector on your existing power supply to a 6 pin PCI Express video card power connector, allowing you to install a PCIe graphics card without having to upgrade the computer power supply.
Product Description StarTech.com 6in LP4 to 6 Pin PCI Express Video Card Power Cable Adapter - Power adapter - 4 pin internal power (M) to 6 pin PCIe power (M) - 6 in - LP4PCIEXADAP - power adapter - 15.2 cm
Type Power adapter
Length 15.2 cm
Connector 2 x 4 PIN internal power - male
Connector (Second End) 6 pin PCI Express power - male
Designed For P/N: ATX2POWER430, ATX2POWER530, RMC4450, ATX2POW500HS, ATX2POW450HS, ATX2POW400HS, ATX2PW550PRO, ATX2PW500PRO, ATX2PW450PRO, ATX2PW400PRO, MICATXPOW255, ATXPOW330HS, ATXPOWER300B, ATXPOW400DF, ATXPOW350PRO, ATXPOW350DF, RMC2300, MICATXPOW145, ATXPOW250PRO, ATXPOW300PRO, ATXPOWER250, ATXPOWER300
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 6in LP4 t...
£3.84
