StarTech.com 6in LP4 to 8 Pin PCI Express Video Card Power Ca...
StarTech.com 6in LP4 to 8 Pin PCI Express Video Card Power Cable Adapter
£8.66
45 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Backed by StarTech.com lifetime warranty
  • Easy to use and install
  • Eliminates the need to upgrade your power supply with an 8-Pin power connector for PCI-Express Video Cards
  • Stock Status: In Stock
Product codes
Convert a standard LP4 power supply connector to an 8-pin PCI Express video card power connector. The LP4PCIEX8ADP 6-inch LP4 to 8-Pin PCI Express Power Adapter converts a standard LP4 power connector on your existing power supply to an 8-pin PCI Express video card power connector, allowing you to install a PCIe graphics card without having to upgrade the computer power supply.
Product Description StarTech.com 6in LP4 to 8 Pin PCI Express Video Card Power Cable Adapter - lp4 to PCI express - molex to 8 pin PCIe (LP4PCIEX8ADP) - power adapter - 15.3 cm
Type Power adapter
Length 15.3 cm
Connector 2 x 4 PIN internal power - male
Connector (Second End) 8 pin PCI Express power - male
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 6in LP4 t...
£8.66
