StarTech.com 6in Mini DisplayPort to DisplayPort Video Cable...
StarTech.com 6in Mini DisplayPort to DisplayPort Video Cable Adapter - M/F
£13.71
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Express: Delivered on Monday
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
  • Length: 15.2cm
  • Stock Status: In Stock
Product codes
Connect your DisplayPort monitor to a standard Mini DisplayPort source.
The MDP2DPMF6IN Mini DisplayPort to DisplayPort video cable adapter allows you to add a standard DisplayPort connection port to your existing mini Displayport equipped laptop. Easy to use and install, this cost-effective solution makes it easy for you to go from Mini DP to DP, in order to get the most from your Mini DisplayPort device.
Product Description StarTech.com 6ft Mini DisplayPort to DisplayPort 1.2 Adapter - mDP to DP Converter Cable for Monitor / Display - Thunderbolt Compatible (MDP2DPMF6IN) - DisplayPort cable - 15.2 cm
Type DisplayPort cable
Length 15.2 cm
Connector Mini DisplayPort - male
Connector (Second End) DisplayPort - female
Compliant Standards RoHS
Colour Black
Designed For P/N: CDP2DP141MB, CDP2DP146B, CDP2DPMM1MB, CDP2DPMM6B, DISPLPORT10L, DISPLPORT15L, DISPLPORT3L, DISPLPORT6L
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 6in Mini...
£13.71
