StarTech.com 6in PCI Express Power Splitter Cable
£10.48
17 in stock
Delivery:
Standard: 1-3 working days
  • Length: 15cm
  • Stock Status: In Stock
Product codes
Split a single PCI Express 6-pin power connection into two power connections. The PCIEXSPLIT6 PCI Express power splitter cable (6-pin to dual 6-pin) lets you connect a single (standard) 6-pin PCI Express power connection provided by the computer power supply to two nVidia SLI or ATI CrossfireX video cards that require a 6-pin power connection.
A cost-saving solution, this PCIe 6-pin to dual 6-pin power cable eliminates the expense of upgrading a computer power supply for the sake of compatibility with dual video card systems.
Product Description StarTech.com 6in PCI Express Power Splitter Cable - power splitter - 15 cm
Type Power splitter
Length 15 cm
Connector 6 pin PCI Express power - male
Connector (Second End) 2 x 6 pin PCI Express power - female
Colour Yellow
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 6in PCI E...
£10.48
