StarTech.com 6in SATA Power to 6 Pin PCI Express Video Card P...
StarTech.com 6in SATA Power to 6 Pin PCI Express Video Card Power Cable Adapter
£5.64
42 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Backed by StarTech.com lifetime warranty
  • Converts two 15-pin Serial ATA power supply connectors to one 6-pin PCIe connector
  • Eliminates the need to upgrade your existing SATA power supply in order to use a PCI Express video card
  • Stock Status: In Stock
Product codes
Convert two 15-pin SATA power supply connectors to a 6-pin PCI Express video card power connector. The SATPCIEXADAP SATA to PCI Express Video Card Power Adapter Cable features a 6-pin PCI Express (female) power connector as well as two 15-pin SATA (male) power connectors, providing a cost-effective way to connect a PCIe video card to Serial ATA power connectors provided by the computer power supply, and eliminating the need to upgrade the power supply for the sake of video card compatibility.
Product Description StarTech.com SATA Power to 6 Pin PCI Express Video Card Power Cable Adapter - power cable - 15 cm
Type Power cable
Length 15 cm
Connector 2 x 15 pin Serial ATA power - male
Connector (Second End) 6 pin PCI Express power - male
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 6in SATA...
£5.64
