StarTech.com 6in SATA Power to 8 Pin PCI Express Video Card P...
StarTech.com 6in SATA Power to 8 Pin PCI Express Video Card Power Cable Adapter
£5.73
19 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Backed by StarTech.com lifetime warranty
  • Converts two 15-pin Serial ATA power supply connectors to one 8-pin PCIe connector
  • Eliminates the need to upgrade your existing SATA power supply in order to use a PCI Express video card
Product codes
Convert two 15-pin SATA power supply connectors to an 8-pin PCI Express video card power connector. The SATPCIEX8ADP SATA to PCI Express Video Card Power Adapter Cable features an 8-pin PCI Express (female) power connector as well as two 15-pin SATA (male) power connectors, providing a cost-effective way to connect a PCIe video card to Serial ATA power connectors provided by the computer power supply - eliminating the need to upgrade the power supply for the sake of video card compatibility.
Product Description StarTech.com SATA Power to 8 Pin PCI Express Video Card Power Cable Adapter - power cable - 15 cm
Type Power cable
Length 15 cm
Connector 2 x 15 pin Serial ATA power - male
Connector (Second End) 8 pin PCI Express power - male
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 6in SATA...
£5.73
