StarTech.com 6in SATA to Left Angle SATA Serial ATA Cable
£3.94
Delivery:
Product codes
Make a Left-Angled Connection to your SATA Drive, for Installation in Tight Spaces. The SATA6LA1 Left Angle (90-degree) SATA Cable features a standard (straight) SATA receptacle as well as a left-angled SATA receptacle, providing a simple 6-inch connection to a Serial ATA drive, with full SATA 3.0 bandwidth support of up to 6Gbps when used with SATA 3.0 compliant drives.
The left-angled SATA connection enables you to plug in your Serial ATA hard drive in hard to reach areas or tight spaces, while the low profile and flexible design of the cable improves airflow and reduces clutter in your computer case, helping to keep the case clean and cool.
As an alternative, StarTech.com also offers a 6in Right Angle SATA cable (SATA6RA1), which provides the same simple installation as this left angled SATA cable, but allows the cable to connect to the SATA drive from the opposite direction.
Product Description StarTech.com 6in SATA to Left Angle SATA Serial ATA Cable - 6in SATA Cable - left angle SATA Cable - angled SATA Cable - SATA cable - 15.2 cm
Type SATA cable
Interface Speed Serial ATA 150/300/600
Technology Shielded
Features Left-angled connector
Length 15.2 cm
Connector 7 pin Serial ATA - receptacle
Connector (Second End) 7 pin Serial ATA - receptacle
Colour Red
Designed For P/N: 25S22M2NGFFR, 25SAT22MSAT, S322M225R, SAT2M2NGFF25, SAT32M225, SAT32MSAT257, USB2SATAIDE, USB3SSATAIDE
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 6in SATA...
£3.94
