StarTech.com 6in SATA to Right Angle SATA Serial ATA Cable
£3.92
More than 50 in stock
Delivery:
Standard: 1-3 working days
Product codes
Make a right-angled connection to your SATA drive, for installation in tight spaces. The SATA6RA1 Right Angle (90-degree) SATA Cable features a standard (straight) SATA receptacle as well as a right-angled SATA receptacle, providing a simple 6-inch connection to a Serial ATA drive, with full SATA 3.0 bandwidth support of up to 6Gbps when used with SATA 3.0 compliant drives.
The right-angled SATA connection enables you to plug in your Serial ATA hard drive in hard to reach areas or tight spaces, while the low profile and flexible design of the cable improves airflow and reduces clutter in your computer case, helping to keep the case clean and cool.
As an alternative, StarTech.com also offers a 6in Left Angle SATA cable (SATA6LA1), which provides the same simple installation as this right angled SATA cable, but allows the cable to connect to the SATA drive from the opposite direction.
StarTech.com 6in SATA to Right Angle SATA Serial ATA Cable - SATA cable - 15.24 cm
SATA cable
Interface Speed
Serial ATA 150/300/600
Shielded
Right-angled connector
Length
15.24 cm
Connector
7 pin Serial ATA - receptacle
Connector (Second End)
Red
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 6in SATA...
£3.92
