StarTech.com 6in Slimline SATA to SATA Adapter with Power - F/M
£8.59
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Backed by StarTech.com lifetime warranty
  • Cost-effective way to connect a Slimline SATA optical drive to a standard SATA motherboard, using standard SATA cables
  • The 6-inch cable format reduces strain on, and prevents damage to the Slimline SATA drive connector and provides flexibility to position your Slim SATA drive as needed within your system case
  • Stock Status: In Stock
Product codes
Connect a Slimline SATA optical drive up to 6in away from a standard SATA motherboard connection. The SLSATAADAP6 Slimline SATA to SATA adapter features a Slimline Serial ATA connector on one end and a standard SATA data connector (with SATA power connector) on the other, enabling you to connect a Slimline SATA optical drive to standard motherboard and power supply connections.
The slim SATA adapter offers 6-inches in cable length, which compared to standard (non-cable) SATA/Slimline SATA adapter reduces strain off the drive connector and allows for flexible cable routing when positioning the Slimline SATA drive within the system case.
Product Description StarTech.com 6in Slimline SATA to SATA Adapter with Power - F/M - SATA adapter
Type SATA adapter
Interface Speed Serial ATA 150/300/600
Connector 13 pin Slimline Serial ATA - female
Connector (Second End) 22 pin Serial ATA - male
Colour Red
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 6in Sliml...
£8.59
