StarTech.com 6in TX3 Fan Power Splitter Cable
£3.37
31 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Re-position fans to provide optimal cooling to your system
  • Eliminate the cost of a power supply upgrade for compatibility with two system fans
  • Guaranteed dependability
  • Length: 15cm
  • Stock Status: In Stock
Product codes
Connect two 3-pin (TX3) fans to a single power supply connector. The TX3SPLITTER 6in TX3 Fan Power Splitter Cable lets you connect two 3-pin (TX3) fans to a single power supply connector, allowing you to optimize your cooling capability without having to upgrade the power supply.
The 6 inch Y-Cable extends the length of the connection from the computer power supply, offering greater flexibility in positioning the fans within the system case.
Product Description StarTech.com 6in TX3 Fan Power Splitter Cable - Fan power splitter - 3 pin internal power (F) to 3 pin internal power (M) - 5.9 in - TX3SPLITTER - fan power splitter - 3 PIN internal power to 3 PIN internal power - 15 cm
Type Fan power splitter
Length 15 cm
Connector 3 PIN internal power - female
Connector (Second End) 2 x 3 PIN internal power - male
Designed For P/N: FAN12025PWM, FAN5X1TX3, FAN8025PWM
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 6in TX3 F...
£3.37
