StarTech.com 6in USB 2.0 Cable - USB A Female to USB Motherbo...
StarTech.com 6in USB 2.0 Cable - USB A Female to USB Motherboard 4 Pin Header F/F
£5.02
More than 50 in stock
Delivery:
Standard: 1-3 working days
  • Length: 15cm
  • Stock Status: In Stock
Product codes
This USB A Female to Motherboard Header Adapter features a 4-pin USB header connection, as well as a regular USB A (female) port, allowing you to connect internal USB devices directly to the motherboard header connection. The adapter cable offers a cost-effective solution for connecting multi-function front panels, or any device that relies on using an internal USB port.
Product Description StarTech.com 6in USB 2.0 A to USB 4 Pin to Motherboard Header Adapter F/F - USB cable - USB (F) to 4 pin USB 2.0 header (F) - USBMBADAPT - USB cable - 15 cm
Type USB cable
Length 15 cm
Connector 4 pin USB Type A - female
Connector (Second End) 4 pin USB 2.0 header - female
Designed For P/N: 35FCREAD, 35FCREADBK, 35FCREADREM
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 6in USB 2...
£5.02
