StarTech.com 6in USB 3.0 Extension Cable
£4.88
Delivery:
Product codes
Extend the reach of your USB 3.0 port by 6 inches. The USB3EXT6INBK USB 3.0 extension cable extends the reach of a USB 3.0 port on your laptop or desktop computer by 6 inches and gives you more room for connecting multiple devices.
The cable can also help to prevent damage to the USB 3.0 port on your computer in testing environments or other situations where the port is accessed repeatedly.
The extension allows you to connect multiple devices at once, such as flash drives, and gives you open access to ports, even when they are located closely together.
The cable can also be used as a port saver in busy environments where cables are unplugged and re-inserted frequently.
Product Description StarTech.com 6in Short USB 3.0 Extension Adapter Cable (USB-A Male to USB-A Female) - USB 3.1 Gen 1 (5Gbps) Port Saver Cable - Black (USB3EXT6INBK) - USB extension cable - USB Type A to USB Type A - 15.2 cm
Type USB extension cable
Features Molded
Length 15.2 cm
Connector 9 pin USB Type A - female
Connector (Second End) 9 pin USB Type A - male
Compliant Standards USB 3.0
Colour Black
Designed For P/N: 35FCREADBU3, HB30A4AIB, HB30C4AIB, HB31C4AB, SU2DUPERA11, USB3SAA3MBK
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 6in USB 3...
£4.88
