StarTech.com 7.1 USB Audio Adapter External Sound Card with S...
StarTech.com 7.1 USB Audio Adapter External Sound Card with SPDIF Digital Audio
£27.06
41 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Full 7.1 audio outputs via 3.5 mm mini-jacks
  • Optical S/PDIF input and output
  • Dual microphone input
  • Built-in volume control buttons
  • Full-duplex recording and playback
  • Supports 48/44.1 KHz sample rate for recording and playback
  • Hi-Speed USB 2.0 compliant host interface, with transfer rates up to 480 Mbps
  • Interface: USB 2.0
  • Sound Output Mode: 7.1 channel surround
  • Stock Status: In Stock
Product codes
Turn your laptop or desktop computer into a 7.1-channel home theater-ready sound system. This versatile External USB Sound Card/Audio Adapter offers a high quality solution for upgrading desktop or laptop sound.
Providing a robust USB audio experience, the USB sound card connects to a host computer through a single USB 2.0 connection, to deliver impressive external audio capability that can instantly be swapped between systems, without having to open the computer case for installation.
Supporting analog and digital audio for 2 to 7.1 channel audio applications, the external USB sound card provides a cost-saving upgrade from built-in/on-board sound that turns desktop/laptop sound into a home theater-ready audio solution.
The external USB sound card features easy-to-use volume control and two external microphone inputs - a convenient solution for any audio application requiring high quality sound with multi-input capability with support for 44.1 KHz and 48 KHz sampling rates for both playback and recording.
A more than suitable solution for home theater, gaming or multi-media presentations, the External USB Sound Card is easy to install with plug and play support in Windows XP and Windows Vista operating systems.
The audio adapter's SPDIF optical pass-through port supports two-channel audio, this port does not support 5.1 or 7.1 audio.
Product Description StarTech.com 7.1 USB Sound Card - External Sound Card for Laptop with SPDIF Digital Audio - Sound Card for PC - Silver (ICUSBAUDIO7D) - sound card
Device Type Sound card
Enclosure Type External
Interface Type USB 2.0
Dimensions (WxDxH) 10 cm x 6 cm x 2.5 cm
Weight 100 g
Colour Silver
Sound Output Mode 7.1 channel surround
Sample Rate 48 kHz (max)
Hardware Controls And Indicators Volume control, mute button
System Requirements Microsoft Windows 2000 Server, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2008 R2 (32/64-bits), Windows 8.1 (32/64 bits), Windows 10 (32/64 bits)
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 7.1 USB A...
£27.06
