StarTech.com 7 ft Cat 6 Yellow Molded RJ45 UTP Gigabit Cat6 P...
StarTech.com 7 ft Cat 6 Yellow Molded RJ45 UTP Gigabit Cat6 Patch Cable
£4.14
18 in stock
Delivery:
Standard: 1-3 working days
Key features
  • ETL Verified
  • HIGH PERFORMANCE CAT6 ETHERNET CABLE: 100% copper for error-free Multi Gigabit 1/2.5/5Gbps connections; 10Gbps up to 160'; Fluke patch cord tested to comply w/ANSI/TIA-568-2.D Category 6; ETL Verified
  • POE SUPPORT: 24 AWG stranded copper conductors & UL rated wiring supports up to 100W for PoE devices like VOIP phone & security systems; IEEE 802.3bt & DTE power compliance reduces cable heating
  • QUALITY CONSTRUCTION: ETL & UL certified wire; 50-micron gold-plated connectors prevent rust/corrosion to avoid costly network downtime; High quality PVC jacket resists bending or fraying damage
  • EASY INSTALLATION: 75 foot molded patch cord is easy to connect into high density panels with many cables; Compatible w/Cat5e; Available w/Snagless boots for easy wiring conduit installation
  • SPECS: Length: 75ft (22.8m)
  • Length: 2.1m
  • Colour: Yellow
  • Stock Status: In Stock
Product codes
Make Power-over-Ethernet-capable Gigabit network connections. The C6PATCH7YL Cat 6 Patch Cable (7 ft) meets or exceeds all Category 6 cable specifications to ensure reliable Gigabit network connections, and features a durable yellow PVC jacket that enables you to color code your network cable runs as needed. To ensure long-lasting performance, this high quality Cat 6 patch cable features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles - reducing the risk of cable damage, which could decrease network performance. Constructed of only top quality materials, this Gigabit Patch Cable delivers reliable performance.
Product Description StarTech.com 75ft CAT6 Ethernet Cable - Yellow Molded Gigabit CAT 6 Wire - 100W PoE RJ45 UTP 650MHz - Category 6 Network Patch Cord UL/TIA (C6PATCH7YL) - patch cable - 2.1 m - yellow
Type Patch cable - CAT 6
Wiring Scheme T568B
Wires per Cable 8 wires
Features Molded
Length 2.1 m
Connector RJ-45 - male
Connector (Second End) RJ-45 - male
Colour Yellow
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 7 ft Cat...
£4.14
