StarTech.com 7 ft Cat 6a Blue Shielded Molded 10 Gigabit RJ45...
StarTech.com 7 ft Cat 6a Blue Shielded Molded 10 Gigabit RJ45 STP Cat6a Patch Cable
£10.50
16 in stock
Delivery:
Standard: 1-3 working days
Product codes
Make Ethernet connections with PoE support. This high quality cable ensures dependable Ethernet connectivity, supporting high performance - an excellent choice for Power over Ethernet (PoE) applications. Plus cables are backward-compatible with Cat5e and Cat6 cables, ensuring versatile network connection options.
All of the cables are constructed of high quality shielded copper pairs to protect against noise and EMI/RFI interference, ensuring that Cat 6a cables are more than suitable for Ethernet networks and Power over Ethernet applications.
Product Description StarTech.com 7 ft Blue Cat6a / Cat 6a Shielded Patch Cable 7ft - patch cable - 2.1 m - blue
Type Patch cable - CAT 6a
Technology Shielded twisted pair (STP)
Wiring Scheme T568B
Shielding Material Aluminium-polyester foil
Features Molded
Length 2.1 m
Connector RJ-45 - male
Connector (Second End) RJ-45 - male
Colour Blue
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 7 ft Cat...
£10.50
