StarTech.com 7 ft Cat 6a Gray Shielded Molded 10 Gigabit RJ45...
StarTech.com 7 ft Cat 6a Gray Shielded Molded 10 Gigabit RJ45 STP Cat6a Patch Cable
£10.62
24 in stock
Delivery:
Standard: 1-3 working days
  • Length: 2.1m
  • Colour: Grey
  • Stock Status: In Stock
Product codes
Make Ethernet connections with PoE support. This high quality cable ensures dependable Ethernet connectivity, supporting high level of performance and is an excellent choice for Power over Ethernet (PoE) applications. Plus, Cat 6a cables are backward-compatible with Cat5e and Cat6 cables, ensuring versatile network connection options. All of the Cat 6a cables are constructed of high quality shielded copper pairs to protect against noise and EMI/RFI interference, ensuring that the Cat 6a cables are more than suitable for Ethernet networks and Power over Ethernet applications.
Product Description StarTech.com 7 ft CAT6a Ethernet Cable - 10 Gigabit Category 6a Shielded Snagless RJ45 100W PoE Patch Cord - 10GbE Gray UL/TIA Certified - patch cable - 2.1 m - grey
Type Patch cable - CAT 6a
Technology Shielded twisted pair (STP)
Wiring Scheme T568B
Shielding Material Aluminium-polyester foil
Features Molded
Length 2.1 m
Connector RJ-45 - male
Connector (Second End) RJ-45 - male
Colour Grey
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 7 ft Cat...
£10.62
