This 7 Port USB 2.0 Hub connects to one USB 2.0 port on a Mac or PC computer, adding seven USB 2.0 ports - allowing you to maximize the number of high speed USB peripherals connected to your computer. The hub supports cascaded installation with other USB 2.0 hubs, supporting up to 127 USB 2.0 device connections - a scalable solution for connecting multiple USB devices to a single host computer.
The 7 port hub includes a power adapter, but can be powered through USB bus connection to the host computer - allowing you to install the hub as needed without worrying about the availability of a power outlet.
The USB 2.0 hub offers an attractive black casing that suits any operating environment and includes a 3ft USB 2.0 A/B male-male cable, for the connection between the hub and the host computer.
Product Description | StarTech.com 7 Port USB 2.0 Hub – Portable and Compact – Bus Powered USB 2.0 Extender – USB Multiport Expander (ST7202USB) - hub - 7 ports | Device Type | Hub - 7 ports | Subtype | USB | Ports | 7 x USB 2.0 | Dimensions (WxDxH) | 4.8 cm x 8 cm x 2.5 cm | Weight | 272 g | Colour | Black | System Requirements | Apple MacOS 8.6 or later, Microsoft Windows 98SE/2000/ME/XP, Microsoft Windows Vista, Microsoft Windows 2003 | Localisation | United Kingdom | Manufacturer Warranty | 1-year warranty |
General | |
Enclosure Type | Desktop |
Subtype | USB |
Status Indicators | Power |
Expansion / Connectivity | |
Interfaces | 7 x USB 2.0 Type A , 1 x USB 2.0 Type B |
Power | |
Power Device | External power adapter |
Miscellaneous | |
Colour | Black |
Cables Included | 1 x USB cable - 91 cm |
Compliant Standards | UL, FCC, RoHS |
Software / System Requirements | |
Software Included | Drivers & Utilities |
OS Required | Apple MacOS 8.6 or later, Microsoft Windows 98SE/2000/ME/XP, Microsoft Windows Vista, Microsoft Windows 2003 |
Dimensions & Weight | |
Width | 4.8 cm |
Depth | 8 cm |
Height | 2.5 cm |
Weight | 272 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
