StarTech.com 7 Port Industrial USB 3.0 Hub
£102.26
48 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Protects your connected devices with 15kV Air and 8kV Contact ESD protection
  • Surge protection of 350W on the downstream and upstream USB ports
  • Mount industrial USB hub where required with built-in mounting brackets or included DIN rails
  • Type: USB Hub
  • Ports: 7
  • Stock Status: In Stock
Product codes
Add seven USB 3.0 ports with this DIN rail or surface-mountable metal hub. Engineered to meet the challenges of tough industrial environments, this USB 3.0 hub lets you expand your connectivity options by adding seven external USB 3.0 ports to your computer.
Now you can increase your everyday productivity by gaining powerful and convenient access to your external hard drives, printers, mobile devices and other peripherals.
Designed for performance and durability, the industrial-grade hub features a rugged, metal housing. Its wide-range 7-48V DC terminal block input gives you the flexibility to power the hub as required, based on your own power input capabilities. Plus, it supports an extended operating temperature range (0°C to 70°C), helping to ensure reliable performance even in the most demanding factory and industrial environments.
The rugged hub also offers ESD protection to each USB port, which can help safeguard your investments by preventing damage to your connected devices.
This wall-mountable USB 3.0 hub can be securely mounted to surfaces, under desks, and in other high traffic areas where there is a concern that USB connections may become unplugged. Plus, it also includes optional DIN rail mounts for use with equipment rack installations.
Compliant with SuperSpeed USB 3.0, this industrial hub supports 5Gbps bandwidth. It's also backward compatible with USB 2.0 and 1.x specifications, simultaneously supporting older USB peripherals or legacy systems that lack USB 3.0 capabilities.
Product Description StarTech.com 7 Port Industrial USB 3.0 Hub - ESD Protection - hub - 7 ports
Device Type Hub - 7 ports
Subtype USB
Ports 7 x SuperSpeed USB 3.0
Features Surge protection, rugged, 15KV ESD Protector, metal housing
Compliant Standards USB 1.1, USB 2.0, USB 3.0
Power DC 7 - 48 V
Dimensions (WxDxH) 5.5 cm x 12.2 cm x 4.3 cm
Weight 650 g
Colour Black
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 7 Port In...
£102.26
