StarTech.com 7 Port PCI USB Card Adapter
£17.58
More than 50 in stock
Delivery:
Standard: 1-3 working days
  • Type: USB adapter
  • Compatibility: PC
  • Interface: PCI
  • Stock Status: In Stock
Product codes
Add 7 USB 2.0 ports to your PC through a PCI slot. This PCI USB card adds seven USB 2.0 ports (1 internal USB A female, 2 internal USB motherboard header, and 4 external USB A female) to your PCI-capable PC.
The PCI USB 2.0 card is a versatile solution that lets you add USB 2.0 connections without having to upgrade the system motherboard.
An all-in-one solution, the PCI USB card supports USB 2.0 device connections for full data transfer speeds of up to 480Mbps, and is backward compatible with USB 1.1 devices (max. transfer rate 12Mbps), allowing you to connect any USB device to the computer without having to worry about compatibility issues.
The adapter card is designed and constructed to provide long-lasting USB capability.
Product Description StarTech.com 7 Port PCI USB Card Adapter - PCI to USB 2.0 Controller Adapter Card - Full Profile Expansion Card (PCIUSB7) - USB adapter - 7 ports
Device Type USB adapter
Form Factor Plug-in card
Interface (Bus) Type PCI
PCI Specification Revision PCI 2.2
Bus Voltage Universal (3.3 V & 5.0 V)
Dimensions (WxDxH) 12.2 cm x 2 cm x 12 cm
Weight 71 g
Ports Qty 7 ports
Data Link Protocol USB, USB 2.0
Data Transfer Rate 480 Mbps
Compliant Standards USB 1.1, USB 2.0
System Requirements Linux, Microsoft Windows 98SE/2000/ME/XP, Microsoft Windows 7, Microsoft Windows Vista
Manufacturer Warranty 1-year warranty
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 7 Port PC...
£17.58
