StarTech.com 7 Port PCIe USB 3.0 Card
£58.58
27 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Extend your system capabilities by adding 7 USB 3.0 ports – 6 external and 1 internal – to any PCIe compatible computer
  • Unique dual-profile design fits standard and low-profile computers
  • Enjoy fast file transfers with USB 3.0 5Gbps and UASP support
  • Type: USB adapter
  • Compatibility: PC, Unix
  • Interface: PCI Express 2.0 x1
  • Stock Status: In Stock
Product codes
Get the scalability you need by adding 7 USB 3.0 ports with SATA power to your computer. Handle your workload more efficiently. This USB 3.0 card expands your computer's capabilities by giving you seven extra USB 3.0 ports. It's engineered with an innovative stacked port layout to fit easily into both low-profile and standard desktop computers.
More ports means you can add USB devices as you need them. This robust USB 3.0 card gives you seven USB 3.0 ports - six external and one internal - so you can plug in your tablets, smartphones, external hard drives, CD/DVD drives, printer and other devices at the same time. With so many extra ports, you can leave your devices plugged in, so they're ready to use when you need them. It's also economical - by being able to connect so many devices, you save the cost of extra hubs or cards.
The internal USB 3.0 port lets you connect a USB device inside your computer for added convenience and security.
This versatile USB 3.0 card features a dual-profile design with a stacked port layout. The innovative port configuration allows a high number of external ports in a compact design, allowing it to fit both low-profile and full desktop computer systems. A bracket is included for installation into low-profile computers.
You'll be up and running in no time. The card automatically installs in Windows 8, and 8.1, with native operating system support. It's also backward compatible with USB 2.0 and 1.x devices to help you get the most out of your existing peripherals.
This high-performance SuperSpeed USB 3.0 card supports data transfer rates up to 5 Gbps and is enhanced with UASP support, which can perform ~70% faster read speed and 40% faster write speed over traditional USB 3.0, when paired with a UASP-enabled enclosure.
The rugged build quality of the card delivers long-lasting performance, and gives you peace of mind when connecting multiple devices.
UASP (USB Attached SCSI Protocol) is supported in Windows 8, 8.1, Server 2012 and Linux kernel 2.6.37 or later. Test results were obtained using an Intel Ivy Bridge system, StarTech.com add-on USB 3.0 cards, a UASP-enabled StarTech.com enclosure, and a SATA III solid state drive.
Product Description StarTech.com 7 Port PCI Express USB 3.0 Card - Standard & Low-Profile - SATA Power - UASP Support - 1 Internal & 6 External USB 3.0 Ports (PEXUSB3S7) - USB adapter
Device Type USB adapter
Form Factor Plug-in card
Interface (Bus) Type PCI Express 2.0 x1
PCI Specification Revision PCIe 2.0
Dimensions (WxDxH) 12 cm x 10.5 cm x 1.5 cm
Weight 72 g
Data Link Protocol USB, USB 2.0, USB 3.0
Data Transfer Rate 5 Gbps
System Requirements Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Linux 2.6.31 - 4.11.x LTS versions only
Designed For P/N: ST1030USBM, ST7300USBME
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 7 Port PC...
£58.58
