StarTech.com 7 Port SuperSpeed USB 3.0 Hub - Desktop USB Hub...
CLEARANCE
LAST FEW REMAINING
PRICE DROP
StarTech.com 7 Port SuperSpeed USB 3.0 Hub - Desktop USB Hub with Power Adapter – Black
£62.04
More than 50 In Stock
Delivery:
Standard: 1-3 working days
Key features
  • Seven downstream USB 3.0 ports accessible from one side of the hub
  • Compliant with SuperSpeed USB 3.0, with support for up to 5 Gbps
  • Plug-and-Play and Hot-Swap compatible
  • Backward compatible with USB 2.0 and 1.x devices
  • Current overload detection and protection on each USB port
  • Type: USB Hub
  • Ports: 7
Product codes
Add 7 external, USB 3.0 ports to a computer from a single USB connection. The ST7300USB3B USB 3.0 Hub lets you add seven external USB 3.0 ports to a computer from a single USB 3.0 host connection.
Offering data transfer rates up to 5 Gbps, the USB hub meets SuperSpeed USB 3.0 specifications and is backward compatible with USB 2.0 and 1.x devices.
Designed for easy port access when connecting or disconnecting devices, the hub features one-sided port orientation, with current overload detection and protection across all seven ports. The hub supports Plug-and-Play and Hot-Swap technologies, letting you switch and operate your connected devices without having to power down the host computer.
The USB hub is bus powered for use in environments where a power outlet may be unavailable, but is perfect for high-power USB devices when used with the included optional power adapter.
Product Description StarTech.com 7 Port USB 3.0 Hub – Up To 5 Gbps – 7 x USB – Universal Multi Port USB Extender for Your Desktop – USB Powered (ST7300USB3B) - hub - 7 ports
Device Type Hub - 7 ports
Subtype USB
Ports 7 x SuperSpeed USB 3.0
Compliant Standards USB 1.1, USB 2.0, USB 3.0
Dimensions (WxDxH) 20.9 cm x 10.5 cm x 3.5 cm
Weight 140 g
Colour Black
System Requirements Apple MacOS X 10.x, Linux 2.6.x, Microsoft Windows Vista (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2008 R2 (32/64-bits)
Designed For P/N: 2SD4FCRU3, BNDTBUSB3142, PEXUS313AC2V, PEXUSB311A1E, PEXUSB311EI, PEXUSB312A2, PEXUSB314A2V, PEXUSB314A2V2, PEXUSB3S42, SDMSDRWU3AC, SVA12M5NA, USB312SAT3CB, USB315CB2M, USBLT1MW, USBLT1MWS, USBLT2MBR, USBLT2MW, USBLT30CMW, USBLTM1MBK, USBLTM1MWH, UUSBHAUB1RA, UUSBHAUB3LA, UUSBHAUB6IN
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£62.04
