Turn a USB Type-C port on your laptop into five USB Type-A ports (5Gbps) and two USB Type-C ports. This USB-C hub turns your laptop or desktop USB Type-C or Thunderbolt 3 port into four standard USB-A ports, one USB-A fast-charge port, and two USB-C ports. You can also extend the range of your USB devices by using this hub as a mid-point repeater.
The 7-port USB hub provides convenient port access. The extended length of the supplied cable offers the flexibility to position your hub and USB devices as needed, in order to create a comfortable, space-efficient work area. The ports are sufficiently spaced to plug or unplug your USB devices without needing to disconnect other devices from neighboring ports.
With extra USB 3.0 ports, you can increase productivity and connect more devices to your computer, or avoid the hassle of swapping connected devices on your port-limited laptop.
The hub lets you extend the life of your current USB 3.0 devices while also taking advantage of newer USB-C devices.
With the available fast-charge port, the hub helps to ensure that your tablet or smartphone are charged and ready to use when you need them. You can also sync and access your device while it's charging. The USB-A charge port supports USB Battery Charging Specification 1.2.
Product Description | StarTech.com 7 Port USB C Hub with Fast Charge Port, USB-C to 5x USB-A 2x USB-C USB 3.0 (USB 3.1/3.2 Gen 1 SuperSpeed 5Gbps), Self Powered Type-C Hub w/ Power Adapter, Desktop/Laptop Hub - Windows/macOS/Linux (HB30C5A2CSC) - hub - 7 ports | Device Type | Hub - 7 ports | Subtype | USB | Ports | 5 x SuperSpeed USB 3.0 + 2 x USB-C | Features | Plastic housing, Fast Charging Port | Compliant Standards | USB 1.1, USB 2.0, USB 3.0 | Power | AC 120/230 V 1 A | Dimensions (WxDxH) | 14.9 cm x 6.5 cm x 2.4 cm | Weight | 250 g | Colour | Black, silver | Localisation | Australia, Japan, New Zealand, United Kingdom, Europe, North Asia | Manufacturer Warranty | 2-year warranty |
General | |
Enclosure Type | Desktop |
Subtype | USB |
Processor | X VIA VL813 |
Status Indicators | Active |
Expansion / Connectivity | |
Interfaces | 4 x USB 3.0 Type A , 1 x USB 3.0 Type A Fast-Charge , 2 x USB-C |
Power | |
Power Device | External power adapter |
Power Provided | DC 12 V - 4 A |
Voltage Required | AC 120/230 V |
Electric Current Required | 1 A |
Power Consumption Operational | 48 Watt |
Miscellaneous | |
Cables Included | 1 x USB cable - 1 m |
Compliant Standards | FCC, RoHS, USB Battery Charging Specification Rev. 1.2, UASP (USB Attached SCSI Protocol) |
Dimensions & Weight | |
Width | 14.9 cm |
Depth | 6.5 cm |
Height | 2.4 cm |
Weight | 250 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 50 °C |
Humidity Range Operating | 0 - 95% (non-condensing) |
Min Storage Temperature | -20 °C |
Max Storage Temperature | 70 °C |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
