StarTech.com 7 Port USB-C Hub - C to C & A
£73.60
10 in stock
Delivery:
Standard: 1-3 working days
  • Type: USB Hub
  • Interface: USB
  • Ports: 7
  • Form Factor: External
  • Stock Status: In Stock
Product codes
Turn a USB Type-C port on your laptop into five USB Type-A ports (5Gbps) and two USB Type-C ports. This USB-C hub turns your laptop or desktop USB Type-C or Thunderbolt 3 port into four standard USB-A ports, one USB-A fast-charge port, and two USB-C ports. You can also extend the range of your USB devices by using this hub as a mid-point repeater.
The 7-port USB hub provides convenient port access. The extended length of the supplied cable offers the flexibility to position your hub and USB devices as needed, in order to create a comfortable, space-efficient work area. The ports are sufficiently spaced to plug or unplug your USB devices without needing to disconnect other devices from neighboring ports.
With extra USB 3.0 ports, you can increase productivity and connect more devices to your computer, or avoid the hassle of swapping connected devices on your port-limited laptop.
The hub lets you extend the life of your current USB 3.0 devices while also taking advantage of newer USB-C devices.
With the available fast-charge port, the hub helps to ensure that your tablet or smartphone are charged and ready to use when you need them. You can also sync and access your device while it's charging. The USB-A charge port supports USB Battery Charging Specification 1.2.
Product Description StarTech.com 7 Port USB C Hub - USB-C to 5x USB-A and 2x USB-C - USB 3.0 - hub - 7 ports
Device Type Hub - 7 ports
Subtype USB
Ports 5 x SuperSpeed USB 3.0 + 2 x USB-C
Features Plastic housing, Fast Charging Port
Compliant Standards USB 1.1, USB 2.0, USB 3.0
Power AC 120/230 V 1 A
Dimensions (WxDxH) 14.9 cm x 6.5 cm x 2.4 cm
Weight 250 g
Colour Black, silver
Localisation Australia, Japan, New Zealand, United Kingdom, Europe, North Asia
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 7 Port US...
£73.60
