StarTech.com 7 Port USB Charging Station with 5x 1A Ports and...
StarTech.com 7 Port USB Charging Station with 5x 1A Ports and 2x 2A Ports
£60.64
18 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Charge multiple devices simultaneously with five 1A ports and two 2A ports
  • Free up wall outlets using a consolidated charging station
  • Mount the charging strip to a desk or wall with the included mounting bracket
  • Stock Status: In Stock
Product codes
Charge up to seven mobile devices simultaneously. This 7-port USB charging station lets you set up a multiport charge point for tablets, phones and other mobile devices.
This standalone USB charging strip offers five 1A and two 2A USB charging ports, so you can charge several mobile devices at the same time, without having to connect to multiple wall outlets or power bars.
The 7-port charging station supports Smart Charging capabilities, including USB Battery Charging Specification 1.2 and Apple and Samsung protocols, which ensures compatibility with a broad range of mobile devices, like the Apple iPhone and iPad, the Samsung Galaxy Tab, Android devices and more.
Create a dedicated USB charging station at your desk, so you can charge your mobile devices while you work. The charging station is also a great addition to your boardroom or lobby, providing a convenient way for mobile users to keep their devices powered.
With its integrated power button, you can turn all of the ports off while the charger isn't in use.
This compact charging strip takes up minimal space and features a rugged metal housing that can withstand the wear and tear of daily use. With the included wall-mount bracket, you can attach the charging strip to a surface such as a desktop or wall, for easy access to charge ports.
Product Description StarTech.com 7 Port USB Charging Station with 5x 1A Ports and 2x 2A Ports charging strip - + AC power adapter - USB
Product Type Charging strip + AC power adapter
Dimensions (WxDxH) 4.5 cm x 11 cm x 2.4 cm
Weight 126 g
Colour Black
Localisation Europe
Output Connector Type Total 7: USB
Voltage Required AC 100-240 V
Voltage Provided DC 12 V
Max Electric Current 5 A
Power Device Details 5 x - 4 pin USB Type A - 1 A , 2 x - 4 pin USB Type A - 2 A
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£60.64
