StarTech.com 70x15mm Replacement Ball Bearing Computer Case F...
StarTech.com 70x15mm Replacement Ball Bearing Computer Case Fan with TX3 Connector
£6.22
39 in stock
Delivery:
Standard: 1-3 working days
Product codes
Overheating hardware can be a problem in most server rooms. With StarTech.com's 70x70x15mm TX3 Dual Ball Bearing Fan Replacement Fan, you can avoid problems to workstations, and optimize system components for ideal performance.
Product Description StarTech.com 70x15mm Replacement Ball Bearing Computer Case Fan w/ TX3 Connector case fan
Product Type Case fan
Colour Black
Fan Diameter 70 mm
Fan Height 15 mm
Fan Bearing Dual ball bearing
Rotation Speed 3500 rpm
Air Flow 28 cfm
Product Material Plastic
Features Fan speed monitoring
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 70x15mm R...
£6.22
