StarTech.com 75 ft Cat5e Blue Molded RJ45 UTP Cat 5e Patch Cable
£15.88
17 in stock
Delivery:
Standard: 1-3 working days
Key features
  • 100% copper - a better value
  • 24 AWG wire
  • 50-micron gold connectors
  • Length: 22.9m
  • Colour: Blue
  • Stock Status: In Stock
Product codes
Make Fast Ethernet network connections using this high quality Cat5e Cable, with Power-over-Ethernet capability. The M45PAT75BL Cat5e Patch Cable (75 ft) meets or exceeds all Cat 5e specifications to ensure reliable Ethernet network connections, and features a durable blue PVC jacket that enables you to color code your network cable runs as needed. To ensure long-lasting performance, this high quality Cat5e patch cable features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles - reducing the risk of cable damage, which could decrease network performance. Constructed of only top quality materials, this Cat5e Patch Cord delivers reliable performance.
Product Description StarTech.com 75 ft Cat5e Patch Cable with Molded RJ45 Connectors - Blue - Cat5e Ethernet Patch Cable - 75ft UTP Cat 5e Patch Cord (M45PATCH75BL) - patch cable - 22.9 m - blue
Type Patch cable - CAT 5e
Technology Unshielded twisted pair (UTP)
Wiring Scheme T568A
Wires per Cable 8 wires
Features Molded
Length 22.9 m
Connector RJ-45 - male
Connector (Second End) RJ-45 - male
Colour Blue
Designed For P/N: RS232EXTC1, RS232EXTC1EU, RS232EXTC1GB, ST121UTPDVGB, STUTPRXL, USB110EXT, USB120EXT
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 75 ft Cat...
£15.88
