StarTech.com 75 ft Gray Gigabit Snagless RJ45 UTP Cat6 Patch...
StarTech.com 75 ft Gray Gigabit Snagless RJ45 UTP Cat6 Patch Cable
£25.24
Delivery:
Standard: 1-3 working days
Key features
  • 100% copper - a better value
  • 24 AWG wire
  • 50-micron gold connectors
  • Length: 22.9m
  • Colour: Grey
  • Stock Status: In Stock
Product codes
Make Power-over-Ethernet-capable Gigabit network connections. The N6PATCH75GR Cat 6 Patch Cable (75 ft) meets or exceeds all Category 6 cable specifications to ensure reliable Gigabit network connections, and features a durable gray PVC jacket that enables you to color code your network cable runs as needed. To ensure long-lasting performance, this high quality Cat 6 patch cable features a snagless design that protects the RJ45 connector clips from damage and makes the cable less prone to snagging during installation. The cable also features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles - reducing the risk of cable damage, which could decrease network performance. Constructed of only top quality materials, this Cat 6 Patch Cord delivers reliable performance.
Product Description StarTech.com 75 ft Gray Cat6 / Cat 6 Snagless Patch Cable 75ft - patch cable - 22.9 m - grey
Type Patch cable - CAT 6
Technology Unshielded twisted pair (UTP)
Wiring Scheme T568B
Features Snagless
Length 22.9 m
Connector RJ-45 - male
Connector (Second End) RJ-45 - male
Colour Grey
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 75 ft Gra...
£25.24
