StarTech.com 75ft Coax High Resolution Monitor VGA Cable - HD...
StarTech.com 75ft Coax High Resolution Monitor VGA Cable - HD15 M/M
£49.20
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
  • Length: 22.9m
  • Stock Status: In Stock
Product codes
This 75ft High Resolution VGA Monitor Cable is designed to provide the highest video quality possible through VGA. Ideally suited for high resolution VGA applications, this high quality male to male coaxial VGA cable eliminates picture "ghosting" and fuzzy images inherent to non-coaxial cables, and provides superior EMI interference protection by using ferrite cores near the connector ends.
Product Description StarTech.com 75 ft. (22.9 m) VGA to VGA Cable - HD15 Male to HD15 Male - Coaxial High Resolution - High Quality - VGA Monitor Cable (MXT101MMHQ75) - VGA cable - 22.9 m
Type VGA cable
Technology Triple shielded twisted pair coaxial
Features Molded, ferrite bead
Length 22.9 m
Connector HD-15 (VGA) - male
Connector (Second End) HD-15 (VGA) - male
Colour Black
Designed For P/N: CDP2VGA, CDP2VGAFC, VGAPLATE
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 75ft Coax...
£49.20
