StarTech.com 7m 10G SFP+ Active DAC Cable
£101.98
19 in stock
Delivery:
Standard: 1-3 working days
Key features
  • 100% compatibility with Cisco SFP-H10GB-ACU7M guaranteed
  • StarTech.com SFP cables are backed by a lifetime warranty
  • Uses a cost-effective cabling alternative to fiber-optic setups
  • Length: 7m
  • Colour: Black
  • Stock Status: In Stock
Product codes
Connect your Cisco 10GbE SFP+ network devices with this cost-effective, active Twinax copper cable. This 10G SFP+ cable delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
The active twinaxial cable is a fully hot-pluggable solution, supporting 10 Gigabit Ethernet applications connected through SFP+ (Small Form-Factor Pluggable) ports.
Designed for high-speed interconnects, this cable is intended for medium-distance applications such as across-rack network switch or server connections.
Product Description StarTech.com 7m 10G SFP+ to SFP+ Direct Attach Cable for Cisco SFP-H10GB-ACU7M - 10GbE SFP+ Copper DAC 10 Gbps Active Twinax - 10GBase direct attach cable - 7 m - black
Type 10GBase direct attach cable - SFF-8431/SFF-8432
Technology Twinaxial
Features Active cable
Length 7 m
Connector SFP+ - latched
Connector (Second End) SFP+ - latched
Colour Black
OEM Manufacturer Equivalent Part Number Cisco SFP-H10GB-ACU7M
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 7m 10G SF...
£101.98
