StarTech.com 7m 23ft 40G QSFP+ AOC Cable
Select:
Key features
  • Delivers reliable 40 GbE connections
  • StarTech.com SFP cables are backed by a lifetime warranty
  • Complies with Multi-Source Agreement (MSA) industry standards
Product codes
Connect your MSA compliant 40GbE QSFP+ network devices with this cost-effective, active optical cable. This 40G QSFP+ cable delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
This active optical cable (AOC) is fully hot-pluggable and supports 40 Gigabit Ethernet applications connected through QSFP+ (Quad Small Form-Factor Pluggable) ports. The AOC cable is lighter and more flexible than QSFP+ direct-attach cables, which makes it ideal for installation in tight spaces and over longer distances.
Designed for high-speed interconnects, this low-power, low-latency optical cable is ideal for applications such as point-to-point across-rack network switch or server connections.
Product Description StarTech.com MSA Compliant QSFP+ Active Optical Cable - 7 m (23 ft) - 40 GbE - 40GBase direct attach cable - 7 m - black
Type 40GBase direct attach cable - SFF-8436
Technology Fibre optic
Features Active cable
Length 7 m
Connector QSFP+ - latched
Connector (Second End) QSFP+ - latched
Colour Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 7m 23ft 4...
