Connect your Cisco 40GbE QSFP+ network devices with this cost-effective, active Twinax copper cable. This 40G QSFP+ cable delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
The active twinaxial cable is a fully hot-pluggable solution, supporting 40 Gigabit Ethernet applications connected through QSFP+ (Quad Small Form-Factor Pluggable) ports.
Designed for high-speed interconnects, this cable is intended for medium distance applications such as across-rack network switch or server connections.
Product Description | StarTech.com Cisco QSFP-H40G-ACU7M Compatible 7m 40G QSFP+ to QSFP+ DAC Twinax, 40GbE QSFP+ Copper DAC 40 Gbps Low Power Active Transceiver Module DAC, 40GE QSFP+ Cable Firepower ASR1000 - Lifetime Warranty (QSFPH40GACU7) - 40GBase direct attach cable - 7 m - black | Type | 40GBase direct attach cable - SFF-8436 | Technology | Twinaxial | Features | Active cable | Length | 7 m | Connector | QSFP+ - latched | Connector (Second End) | QSFP+ - latched | Colour | Black | OEM Manufacturer Equivalent Part Number | Cisco QSFP-H40G-ACU7M | Manufacturer Warranty | 2-year warranty |
General | |
Network Cable Type | 40GBase direct attach cable - SFF-8436 |
Jacket Material | PVC |
American Wire Gauge (AWG) | 24 |
Impedance | 100 Ohm |
Length | 7 m |
Weight | 450 g |
Colour | Black |
Connectivity | |
Miscellaneous | |
Compliant Standards | FCC, RoHS, MSA |
Manufacturer Warranty | |
Service & Support | 2-year warranty |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 70 °C |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
