StarTech.com 7m HDMI to DVI-D Cable - M/M
£35.35
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Eliminates the need for multiple cables and clutter
  • Ensures compatibility between two distinct digital video interfaces
  • Guaranteed reliability
  • Length: 7m
  • Stock Status: In Stock
Product codes
Connect an HDMI -enabled output device to a DVI-D display, or a DVI-D output device to an HDMI-capable display. The HDDVIMM7M 7m HDMI to DVI-D cable enables you to connect a DVI-D video card (or other DVI-D output device) to a display that incorporates HDMI technology. The cable supports bi-directional operation that also allows the reverse configuration, delivering digital video from an HDMI-enabled output to a DVI-D capable display.
A valuable addition to any digital signage, multimedia or home theater application, this high-performance cable is designed to provide the best quality picture available through either HDMI technology or DVI digital connections.
Product Description StarTech.com 7m HDMI to DVI-D Cable - HDMI to DVI Adapter / Converter Cable - 1x DVI-D Male 1x HDMI Male - Black 7 meters (HDDVIMM7M) - video cable - HDMI / DVI - 7 m
Cable Video cable - HDMI / DVI
Technology Shielded
American Wire Gauge (AWG) 24
Length 7 m
Colour Black
Connector DVI-D - male
Connector (Second End) HDMI - male
Features Moulded
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 7m HDMI t...
£35.35
