StarTech.com 8" Micro USB OTG Cable
£5.11
More than 50 in stock
Delivery:
Standard: 1-3 working days
Product codes
Connect your USB On-the-Go capable tablet or phone to an external drive or other USB 2.0 device. Now, you can download confidential information from your smartphone or tablet to an external drive, without having to use a Wi-Fi or mobile data connection. This 8 in. USB OTG cable gives you the perfect solution for backing up your important research and other data collected while you're on the road.
The cable turns the Micro-USB port on your mobile device into a USB OTG host port, so that you can connect a Micro-USB drive or other Micro-USB device, such as a game controller, directly to your phone or tablet.
The OTG cable features a compact design that's perfect for carrying as a tablet accessory.
Please Note: This adapter will only work with devices that support USB OTG. Please consult your documentation and/or your service provider to ensure that your device supports USB OTG functionality.
StarTech.com 8in USB OTG Cable Micro USB to Micro USB M/M - USB cable - 20.32 cm
USB cable
Double shielded
Length
20.32 cm
Connector
5 pin Micro-USB Type B - male
Connector (Second End)
USB On-The-Go
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 8" Micro...
£5.11
