StarTech.com 8-Port GbE Switch - Managed
£169.11
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
  • Type: Gigabit Ethernet
  • Ports: 8
  • Managed: Yes
  • Stock Status: In Stock
Product codes
Connect up to 8 different GbE devices using this IP30 industrial Ethernet switch with intelligent Layer 2 management. Easily deploy or scale your network with this Gigabit Ethernet switch, adding eight copper Gigabit Ethernet connections. This IP30 industrial network switch provides intelligent Layer 2 management. Its rugged, compact design and wall-mount option with front access make it ideal for demanding applications, even where space is limited.
This Gigabit Ethernet switch lets you expand your network by connecting up to eight RJ45 devices. The 8-Port switch enables up to eight users to share files and devices, such as printers and scanners, over a LAN connection, by enhancing your existing network capacity with additional ports.
With its compact design, you can wall-mount the Gigabit switch to provide convenient front access to ports and indicators. It's ideal for a wide range of applications, including tight installation areas with significant electromagnetic interference, such as control cabinets and panels. The network switch is also DIN-rail mountable.
The scalable switch delivers efficient and stable performance, with Layer 2 management capabilities. This lets you control packet traffic on a busy network, and customize your settings to achieve optimal network performance, offering improved efficiency and reliability.
This rugged network switch features an IP30-rated metal housing and extended temperature range of -40°C to 75°C, which makes it ideal for a wide range of operating conditions. The sturdy metal enclosure offers durability, even in harsh industrial environments.
With support for 10/100/1000Mbps transfer speeds, this managed switch supports full/half-duplex auto-negotiation, jumbo frames and auto MDI/MDIX operation. This lets you connect your network devices quickly and easily, with little to no configuration required.
To help prevent any unnecessary downtime, the switch features redundant 12-58V DC terminal block power inputs, which ensures seamless operation in the event of power dips or failures.
Product Description StarTech.com Industrial 8 Port Gigabit Ethernet Switch - Hardened Compact Layer/L2 Managed Network LAN/RJ45 Switch Mountable -40C to +75C (IES81GW) - switch - 8 ports - Managed
Device Type Switch - 8 ports - Managed
Subtype Gigabit Ethernet
Ports 8 x 10/100/1000
Performance Data transfer rate: 2 Gbps
Jumbo Frame Support 9KB
Routing Protocol IGMP, MLD
Remote Management Protocol HTTP
Features Layer 2 switching, IPv6 support, full duplex mode, wall mountable, Trivial File Transfer Protocol (TFTP) support, tagged VLAN, 6KV ESD Protector, 802.1x authentication, Internet Control Message Protocol (ICMP), 6KV EFT protector
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP)
Dimensions (WxDxH) 14.8 cm x 13.4 cm x 2.5 cm
Weight 496 g
Colour Black
Designed For P/N: SVA12M2NEUA, SVA12M5NA
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 8-Port Gb...
£169.11
